Boss Gt-8
Bossun yeni processoru, gt8. Dolasan haberlere gore ocak 20de, abddeki ismini hatırlamadagım bi teknoloji fuarında tanıtımı yapılıp piyasaya surulcekmis. En önemli değişiklik olarakta artık processorden anfinin efektlerinide değiştirmek olduğunu söylüyor. Daha fazla bilgi için aşağıdaki adresi babelfish (www.altavista.com) den translate ettirince, komik olsada bi ceviri cıkıo oda bu:
http://www.roland.co.jp/products/boss/GT-8.html
With height of the preponderant modeling quality due to COSM, new model GT-8 appears in the floor type multiple エフェクツ GT series of BOSS which acquires tremendous reliance from the professional guitarists. It is, flagship model of professional specification guitar multiple エフェクツ such as progressive constitution such as the dual COSM amplifier section and furthermore the effect group where type increased.
Those where you can call the largest eyeball of GT-8 are the dual COSM amplifier section of complete independent channel 2 specification. The COSM amplifier where the complete modeling of the vintage amplifier and the popularity where you can obtain original amplifier sound are high luxuriously 2 systems by the fact that it loads, width of the sound making and possibility of performance spread rapidly.
It is possible, to be possible in each COSM amplifier, to change to seamless, to mix and to output to allot the amplifier type which differs respectively. In addition, L of stereo output/allotting the amplifier type which differs to R, it can also use.
Furthermore, as for the COSM amplifier of channel 2, changing with pedal operation not only as little as possible, also the change with the strength of picking by the fact that it makes Dynamic mode is possible. By the fact that it selects the optimum COSM amplifier according to the strength of picking, until recently the fine sound make-up which is impossible is possible. It can obtain rich expression power.
Furthermore, in each COSM amplifier, switch is equipped the convenient Advanced Capability solo with such as live stage. You can obtain the sound for the guitar solo which boost makes instantaneous and intense the switch is turned on. In addition, because as for the solo switch, COSM amplifier it is possible, to set with A/B channel each one, the sound variation was freely used, play with the sound which is not buried to the band ensemble, has the existence impression is possible.
As for the effect which is equipped in GT-8, from the fixed turn effect which it is essential to the sound making of the guitar, lining up all the 44 types to the unique effect only of BOSS which is unparalleled in other things. Furthermore, because you can use simultaneously to 13 types, various effects were combined, it corresponds to also the sound making which is wide with room.
Of course, similar to the former GT series, also connected order of effect free. In addition, by the fact that the compressor becomes independent, it reached the point where it can utilize from FX-1 and FX-2 which thoroughly contain colorful effect positively. FX-1/as for 2 in order to be able to use effect simultaneously up to 2, by the fact that standardization is assured, it is possible to do the fine sound making with soft constitution.
GT-8 colorfulness fully loads high quality effect, but when we would like to use the favorite single unit effect which has already embezzled simultaneously and the like, unifying also external effect, in order to be able to utilize, it equips the external loop which becomes independent.
Of course, it is possible to insert external effect to optional position of the effect chain, on/off of external effect (the bypass) it is the program possible in the patch of GT-8.
GT-8 which loads the COSM amplifier of abundant type, basic sound is decided in favorite COSM amplifier type when and, when it modifies that from after and the like, has loaded the pre-amp mode which is convenient.
When it changes to pre-amp mode, as for effect setting of each patch it is possible that way to modify just the COSM amplifier section with all the patch bundles. Comfortable editing environment is actualized.
As for GT-8, the professional specification which can do the colorful sound making with the substance multiple エフェクツ. Operativity and the expandability which support comfortable guitar play in live stage and recording etc. are had.
With foot operation furthermore way it can do fine effect control, the expression pedal and the foot switch connected possibility. Adjusting to the pedal/the switch of GT-8 itself, it can do various controls.
In addition, it is possible to control all elements which form, guitar sound such as the amplifier control which can be linked transfer in channel of the external guitar & the amplifier with the patch change of GT-8 with GT-8.
Furthermore, because it corresponds to also MIDI, remote it operates the patch change of GT-8 from the external MIDI sequencer and the like, also control of the external MIDI equipment is possible with the operation of GT-8. Regarding the setting which combines the equipment many, it can do efficient system management.
In addition as for GT-8, other than connection to input of the guitar & the amplifier, various connections such as connection to the return of the guitar & the amplifier and connection to the line equipment are possible. Furthermore, without impairing the treble quality due to the transaction of operation inside 24 bit it loads also the digital output of コアキシャル which recording it is possible. It can also connect to direct to the digital recorder and the digital mixer.
* Dual COSM amplifier constitution
* GT-8 COSM pre-amp summary
Category Amplifier type Category Amplifier type
JC CLEAN JC-120
Warm Clean -
Jazz Combo
FULL Range
BrightClean - R-FIER R-FIER Cln -
R-FIER Raw -
R-FIER Vnt1 -
R-FIER Mdn1 -
R-FIER Vnt2 -
R-FIER Mdn2 -
TW CLEAN Clean TWIN
Pro Crunch
Tweed
Warm Crunch - T-AMP T-AMP Clean -
T-AMP Crunch -
T-AMP Lead -
Edge Lead -
CRUNCH Crunch
Blues
Wild Crunch -
StackCrunch HiGAIN SLDN
Drive Stack
Lead Stack
Heavy Lead -
COMBO VO Drive
VO Lead
VO Clean
MATCH Drive
Fat MATCH
MATCH Lead METAL 5150 Drive
Metal Stack
Metal Lead
BG LEAD BG Lead
BG Drive
BG Rhythm
Smooth Drive -
Mild Drive - CUSTOM Custom1
Custom2
Custom3
MS STACK MS1959 (I)
MS1959 (II)
MS1959 (I+II)
MS HiGain
POWER Stack -
* GT-8 effect summary
FX-1/2 ADV COMP -
LIMITER
T. WAH
AUTO WAH
TONE MODIFY
GUITAR SIM
TREMOLO
PHASER
FLANGER
PAN
VIBRATO
UNI-V
RING MOD
SLOW GEAR
DEFRETTER
SITAR -
FEEDBACKER
ANTI-FEEDBACK
HUMANIZER
SLICER
WAVE SYNTH -
SUB EQ DELAY Single
PAN
Stereo -
Dual series -
Dual parallel -
Dual L/R -
Reverse -
Analog -
Tape -
Warp -
Modulate -
Hold -
CHORUS Mono
Stereo1
Stereo2
REVERB Ambience
ROOM
Hall1
Hall2
Plate
Spring -
Mod -
COMP BOSS Comp -
BOSS Limiter - FX-2 HARMONIST
PITCH SHIFTER
PEDAL BEND
OCTAVE -
ROTARY -
2x2 CHORUS
AUTO RIFF
GUITAR SYNTH
AC PROCESSOR
SOUND HOLD
SUB DELAY
EQ
WAH
LOOP
OD/DS
PREAMP/SPEAKER
NOISE SUPPRESSOR
FOOT VOLUME
* GT-8 COSM "ADV COMP" type summary
BOSS Comp - Orange -
Hi-BAND - Fat -
Light - Mild -
D-Comp - Stereo Comp -
* GT-8 COSM "LIMITER" type summary
Boss Limitr -
Rack 160D -
Vtg Rack U -
* GT-8 COSM "WAH" type summary
CRY WAH Reso WAH -
VO WAH CUSTOM1
Fat WAH CUSTOM2
Light WAH CUSTOM3
7String WAH
-As for COSM type of sign/effect, it is something which is loaded anew by comparison with GT-6.
- Effect: The number = of effects 44, the number = of simultaneous use effects 13, pre-amp type several = 46 + 3 customs, OD/DS type several = 30 + 3 customs - AD/DA conversion: Analogue-to-digital conversion = 24 bit + AF system, DA conversion = 24 bits - sampling frequency: 44.1kHz - Stipulated input level: - 10dBu - Input impedance: INPUT = 1M Ω - stipulated output level: 0dBu - Output impedance: OUPUT = 2k Ω - digital out: In EIAJ CP1201 and S/P DIF conformity - dynamic range: Above 100dB (IHF-A) - program memory -: Pre-setting = 200, user = 140 - display: 16 columns, 2 lines (back light attachment LCD), 7 segmented 2 columns (LED) - connected terminal: Input and output (L < MONO >/R), headphone and digital out (コアキシャル), external loop (センド/return), amplifier control, sub expression pedal/sub control pedal (1 and 2), MIDI connector (IN/OUT), AC adapter - power source: AC14V (attachment AC adapter) - consumed electric current: 650mA - External size: 515 (W) ×261 (D) ×75 (H) mm, < when pedal tilted maximum > 515 (W) ×261 (D) ×107 (H) mm - mass: 4.8kg (the AC adapter is excluded) - the accessory: AC adapter (BRC-100)
Aynı sitede bunu prototip olduğu ve piyasaya sürülmeyeceği de yazıyor. Ancak karışık mesajlar dönüyor ortada, çıkacak deniyor, çıkmayacak deniyor.
Bir de ben eski GT6 dan pek bir fark göremedim bu yenisinde..? Eskisine 1-2 ekstra özellik eklemişler.. V.01 olan oyunu V.011 olarak piyasa sürmek gibi geldi biraz :D
hangi sitede yazıyo bole bisi? bu ceviriye fazla guvenme eger oyleyse. Rolanddakilere sormuslar bunu bu ne is die hani yeni ne var die, kesinlikle ole deil elinize alınca gorursunuz falan demişler. gt6 yahoogroupsdan aldım ben bu haberi onlar emin konusuolar valla cıkacagından bide.
Auto-Riff ne oluyo bi riff kaydediyosunuz o ritm atarken arkadan solo falan mı gidiyorsunuz ? Öyle birşey olsa süper olur mesela gt6 nın özelliklerini falanda bilmiyomda ondan soruyom
benim anladıgım kadarıyla, aleti belli bi nota dizimine programlıyorsun alet o riffin ilk 2 -3 notasını duyunca baslıo duydugu yerden itibaren calmaya, bunu yabancı forumlardada tartısıolar tam bakmadım ama bole bisidi sanırım
Date: Mon Nov 22, 2004 11:29 am
Subject: Re: [GT-6] GT-8 USA launch date
ADVERTISEMENT
damn i wanted mine this christmas, too bad i have to wait
Nick Oatley <nick.oatley@b...> wrote:
I am told the GT-8 is due to be launched in the USA at the NAMM 2005
show, Jan 20-23, Anaheim Convention Center, CA
Start saving up now!
Nick.
boyle diyorlar ecnebi forumlarinda.
#18
aleti alan insanlar devrim oldugunu fln soluolar ama bilmiorum, japonyada fln cıktı sanırım türkiyede ilk ben alcam :) ocak 20de cıkıomus Namm fuarında, şubat 5 ila 15 arası flnda benim elimde olcak :D insalla döt olmam :p..
