Cakewalk Sonar 5
'Müzik Teknolojileri & Kayıt Forumu' forumunda SwaLLoweD tarafından 2 Kasım 2005 tarihinde açılan konu
  1. Sonar'ın yeni sürümü bir süre önce çıkmış, ben yeni gördüm, sizlerle de paylaşayım dedim...
    Yine hem Sonar Producer 5 hem de Sonar Studio 5 olarak iki ayrı paket halinde geliyor... Bu sürümle yaptıkları en büyük yenilik de native 64-bit desteği de veriyor olmaları sanırım.. Müzik Pc'nizi 64-bit bir sisteme upgrade etmenin zamanı geldi sanırım...
    4.0.4 sürümüne göre yeni gelen özellikleri:
    * PSYN™ II subtractive synth, Pentagon™ I vintage analog synth, Roland® GrooveSynth™, SFZ SoundFont sampler, RXP ™ REX Player groove box
    * Perfect Space™ Convolution Reverb
    * Updated MIDI FX plug-ins
    * SONAR 5 ships as both a 32-bit and 64-bit application with the 64-bit double precision floating point engine being accessible in both versions.
    * BitBridge™ enables 32-bit VST effects and instruments in SONAR’s 64-bit environment
    * Roland® V-Vocal Variphrase™ vocal editing technology
    * Track Templates and Track Icons
    * VST plug-ins are now scanned, loaded, and configured natively in SONAR
    * Enhanced Track Layers for even more comping and editing power
    * Integrated inline audio and MIDI editing, arranging, and mixing all in one view
    * MIDI sequencing enhancements including advanced step recording
    * Plug-ins and Edit views may be docked and tabbed right in the Track View for easy access when arranging, editing or mixing your project
    * Envelope automation drawing enhanced with tempo-sync patterns, freehand, more
    * Object-oriented clip-based effects and editing including per-clip effects bin, clip-based effect automation, and more
    * Enhanced Group Editing and Group Manager
    * Remove DC offset during recording
    * Bus and synth waveform preview to give you the visual feedback you need to fix it in the mix through markers that display overs and peaks
    * Video output to 1394 FireWire devices for high quality viewing with lower CPU and disk usage
