Bogner Amfileri
'Elektro Gitar Ekipmanı' forumunda sweetrock tarafından 24 Ocak 2013 tarihinde açılan konu
  1. 2013 NAMM'de yeni Bogner ATMA görücüye çıkıyor .
    Bir başka yurtdışı forum da rastladım , paylaşayım dedim kendi kendime :)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Yukarıda ki de Bogner abimiz olmalı :)
    The Bogner 'ATMA'
    One's soulful essence meets at the nexus of past and future. Where old tradition morphs into new and iconic tools are re-envisioned for the modern hand. This is our newest creation - Atma.
    The effortlessly smooth and rounded corners are perhaps the first detail noticed of Atma's unique hybrid aluminum and wood construction. Not only is it a beautiful artistic statement that's incredibly strong and durable but it also delivers detailed midrange and tonal clarity. Light weight, portable and evolved, Atma is equally comfortable on a greasy juke-joint stage or penthouse apartment looking over the city lights. A thin aluminum outer-shell allows for considerably smaller sizes for traveling light while the wooden speaker baffle board projects classic organic tones.
    Within Atma you can feel the influence of Reinhold Bogner's grandfather, who owned an aluminum factory, as well as his respect for famed industrial designer Dieter Rams. This was the modernist era of air-stream travel-lodges, glass walled homes and experimental materials used on futuristic concepts. And once again, past design ideas and approaches are being challenged and pushed forward by Reinhold Bogner and Atma.
    Atma includes:
    - el84 power tubes for 18 watts
    - ec81 rectifier tube
    - three channels: clean, crunch and lead channels. clean has a balanced tone control while crunch and lead channels share gain, treble, middle and bass eq controls. channels are accessed via the foot-switch or front panel three-way selector switch
    - crunch channel has gain pot on back panel to control gain structure from crunch to lead gain levels
    - three-way switch for 60's, 70's, 80's gain, voicing and compression. 80's mode is great for attaining hi-gain tube saturation at bedroom levels with inspiring feel and tone
    - three way bright switch
    - power attenuator from 18w, 5w or 1w
    - effects loop with send and return jacks
    - aluminum head shell and speaker cabinet (baltic birch-ply baffle board)
    sacthres ve mistreated4u bunu beğendi.
  2. Pembe .. Cesur bir tasarım. :) Rahat taşınabilmesi için bir sapı da olmalıydı bence.
  3. Bu forum da bu seviye sevenleri az galiba ?
    [​IMG]
  4. Crunch kanalını çok merak ediyorum, tasarımı da çok güzel olmuş.
  5. Üstad bir de genel olarak Bogner başlığı gibi olmuş sen başlığı öyle yazınca, ama sadece Bogner'in yeni bir amfisini tanıtmak için açılmış başlık.
  6. Büyük ihtimalle "Atma" modeliyle başlayıp diğer modellerle zenginleşsin diye öyle açmıştır Hakan abi başlığı, bence öyle olursa süper olur.
    sweetrock bunu beğendi.
  7. Aslında genel olarak Bogner başlığı açtım ,
    Yenilikleri zaman zaman eklemek arzum .
  8. Eskilikleri eklemek lazım asıl, Tabi bilen eden olmalı.
  9. Nonoş Bogner Ağabeyimiz kendisi sunuyor ,
    Çalana bakıp da , ben de aynı sesleri çıkartırım demeyin sakın .
  10. Aman abi, adamın tasarımsal tercihleri ilgi alanımız, dötsel değil :D
    İsim de üstünde Türkçe söz oyunları yapmaya yatkınmış. Sanki "atmış" da tutturmuş misali, tele ile biraz Marshall tadında olmuş :)
  11. [​IMG]
    4 yeni pedal daha !
  12. Tamam da simdi boyle dar takim ustunde bir de kemik gozluk takan bir adam mi okuz gibi distortion veren Uberschall'i tasarlamis, olacak is degil diye dusunuyoruz yani dotumuz(bottom end'i kastediyorum eheh farkli anlarsaniz iciniz fesat demek) atiyor sonra amfideki dot (yanlis anlasilmasin bottom end'i kastediyorum yine:) ) neredeyse kimsede yok lakin her urun tasarimcisindan izler tasiyor iste buradaki benzerlik de dot bazinda(efendim bottom end diyorum yanlis yere cekmeyelim lutfen):) ... Soyle acikliyayim ben bu herifi ilk burada bir amfi fuarinda gordum (yaaa elin gavuru sadece butik amfi icin fuar yapiyor denemek de serbest ustadim); Motorhead'in solistinin aslinda Lemmy degil de Kusum Aydin oldugunu (allah korusun) ogrensem ancak bu kadar dehsete duserim diyebilecegim bir dumur olmustu benim icin...
  13. paramı dayanır bunlara ..kasap önündeki kedi gibi hissettim bir an..
  14. Bottom End ile işimiz olaydı milletçenek Zeki Müren dinlemezdik :)
