Satılık Morley Pro Series Volume Plus Pedal
'Elektro Gitar Pedal ve Processorleri' forumunda zxcvbnm tarafından 24 Nisan 2016 tarihinde açılan konu
  1. Şehir:
    İstanbul
    Fiyat:
    200 TL
    Takasa:
    kapalı
    Sıfırdan hiç bir farkı yoktur. Sadece evde kullanıldı ayakkabı ile dahi basılmamıştır. Lütfen aşağıdaki videoyu izlemeyi ihmal etmeyin volume pedal da bundan iyisini görmedim.
    Türkiyenin her yerine kargo ile yollayabilirim.
    The Morley Volume Plus was developed from many user requests for a switchable Minimum Volume control. Minimum Volume control allows users to use the volume guitar pedals for either a Lead/Rhythm pedal or a standard Volume control pedal. Electro-Optical Volume footpedal is consistent and studio quiet (no pots to wear out). AUDIO taper allows smooth volume control or violin type swells. Minimum Volume knob is used for a smooth transition between rhythm and lead volumes. Works with Guitar, Bass, Keys or any other instrument you need to control volume on.
    Some found it inconvenient to have to turn down the Min Vol knob and then have to reset it when using either function. Now, the Minimum Volume feature is foot switchable so it can easily be used as Lead/Rhythm pedal or Volume pedal.
    FEATURES
    • Switchable Minimum Volume control
    • AUDIO taper allows smooth volume control or violin type swells
    • LED indication, easy access battery compartment.
    SPECIFICATIONS
    Volume Plus Pedal
    • POWER: 9V Battery or Morley 9VDC 300 mA regulated adapter (center pin is negative)
      CURRENT DRAW: 2.5 mA @ 9 VDC
      CONTROLS: Switchable Minimum Volume
      TAPER: Audio
      WEIGHT: 3.3 lb./ 1.51 kg
      INDICATOR: Power LED on
      Dimensions: 9.13"(L) x 5.88"(W) x 2.75"(H)
    Son düzenleme: 9 Eylül 2016
    dingdongdaddy bunu beğendi.
  2. Fiyat 180 lira oldu. İstanbul tünele kadar elden teslim edebilirim
