Satılık Electro Harmonix Mel9 Tape Replay Machine
'Elektro Gitar Pedal ve Processorleri' forumunda ChordSolo tarafından 22 Haziran 2016 tarihinde açılan konu
  1. Şehir:
    Proje değişikliği yüzünden kullanmadan satıyoruz:
    - Pays homage to nine of the coolest Mellotron® sounds: Orchestra, Cello, Strings, Flute, Clarinet, Saxophone, Brass, Low Choir and High Choir
    - Works on guitar without modifications, special pickups or MIDI implementation and tracks bends, slides, even whammy dive bombs!
    - Also works with bass guitar down to the open A string as well as keyboards within the limits of its polyphony (5 notes) and range A1 to A5)
    - Includes independent Effect and Dry volume controls so you can create the perfect mix at the Effects output
    - Dry Output jack outputs your input signal at unity gain
    - Attack control sets the volume swell speed. As it’s turned clockwise the notes fade in more gradually
    - Sustain control adjusts the release time after a sound is stopped. As it’s turned clockwise, the fade out time increase
    pcp41, fade2black, ilkinkazan ve 2 kişi daha bunu beğendi.
  2. Cok merak ettigim bir pedaldi. Durumlar uygun olsaydi keske. Iyi satislar dilerim.
    ChordSolo bunu beğendi.
  3. teşekkürler...
  4. Cuzdanim kaşiniyor :(
