Satılık Musicman Axis
'Elektro Gitarlar' forumunda blackneuron tarafından 26 Ağustos 2016 tarihinde açılan konu
  1. Şehir:
    İstanbul
    Fiyat:
    6000TL
    Takasa:
    açık
    Merhaba,
    Su linkten Axis detayli bilgi alinabilir. Matching headstock dur.
    Gitar fotograflarda gorulecegi uzere 0 dan farksizdir kilcal cizik dahi yoktur, mantikli ekipmanlarla takas olur.
    6000TL
    Size 12-5/8" wide, 1-3/4" thick, 36-1/4" long (32.1 cm wide, 4.5 cm thick, 92.0 cm long)
    Weight 7 lbs, 4 oz (3.29 kg) - varies slightly
    Body Wood Basswood with bookmatched figured maple top
    Body Finish High gloss polyester
    Body Colors Back and Sides - Opaque Black; Choice of flame or quilt top in Trans Gold, Balboa Blue Burst or Natural Gloss
    Body Bindings Binding - Cream
    Bridge Music Man® double locking tremolo with fine tuners; lowers pitch only
    Scale Length 25-1/2" (64.8 cm)
    Neck Radius 10" (25.4 cm)
    Headstock Size Only 5-7/8" (14.9 cm) long
    Frets 22 - High profile, medium width
    Neck Width 1-5/8" (41.3 mm) at nut, 2-3/16" (55.6 mm) at last fret
    Neck Wood Select maple neck
    Fingerboard Select maple
    Neck Finish Gunstock oil and hand-rubbed special wax blend
    Neck Colors Standard - Natural; Optional - Matching painted headstock
    Tuning Machines Schaller M6LA with pearl buttons
    Truss Rod Adjustable - no component or string removal
    Neck Attachment 5 bolts - perfect alignment with no shifting; Sculpted neck joint allows smooth access to higher frets
    Electronic Shielding Graphite acrylic resin coated body cavity and aluminum lined control cover
    Controls 500kohm volume pot
    Switching 3-way toggle pickup selector
    Pickups HH - 2 DiMarzio custom humbucking
    cmbp, BABAJi, sweetrock ve 15 kişi daha bunu beğendi.
  2. ama ama ama...olmaz ki..:cry:
  3. Sapı yeter :O
