Satılık Kustom Defender 5h Kafa Ve 1*12 Kustom Defender Kabin
'Elektro Gitar Amplileri' forumunda nurialcho tarafından 16 Ekim 2016 tarihinde açılan konu
  1. Şehir:
    İstanbul
    Fiyat:
    650 lira
    Takasa:
    kapalı
    [​IMG]
    Detaylı fotolar için:
    https://www.sahibinden.com/ilan/iki...e-1-12-kustom-defender-kabin-353684853/detay/
    Tertemiz ,az kullanılmış ve sorunsuzdur.
    Full lambalı kafa ve 1*12 kabin.
    Kabinin sıfır fiyatı 650 lira ,kafanın sıfır fiyatı ,850 lira civarında.
    Gayet hafif ve kolayca taşınabilecek bir kafa kabin. 3 kilo kafa ,9 buçuk kilo kabin.
    TAKAS YOKTUR !!!
    Ayrı ayrı da satılıktır kafa da kabin de 350 lira pazarlıksızdır.
    Amfi Tipi
    : Kafa
    Amfi Türü
    : Lambalı
    Empedans
    : 16 Ohm
    Empedans
    : 4 Ohm
    Empedans
    : 8 Ohm
    Tüpler
    : 12AX7
    Tüpler
    : EL84
    Watt Değeri
    : 5W
    Kustom DEFENDER 5H - 5W All Tube Head
    Is there anything more fun than a low-wattage all-tube amp head that provides authentic, cranked up tube tone at modest volume levels? We think not. And did we say “simple?” The new Defender 5-watt Model 5H guitar head has one knob! (Volume) But the fun lies in hearing what this knob does as you slowly turn it up. Starting in the counterclockwise position, you’ll move through clean and clear tube tones to progressively dirtier sounds until this little sucker is just plain screaming!
    This “clean-to-mean” response isn’t due to any overdrive or distortion circuit, it’s just the sound of the single EL84 power tube moving naturally into increased output distortion. And it’s great for cranking up and controlling the action right from your guitar’s volume control – no channel switching required!
    Features include one 12AX7 preamp tube, one EL84 power tube and three speaker outputs (4, 8, and 16-ohm). By the way, the Defender 5H head is designed to match perfectly with the Defender 1x12 speaker cabinet. This cabinet is loaded with one 12-inch Kustom speaker that handles 30 watts. Check it out!
    RMS Wattage: 5 Watts
    Speaker: N/A
    Cabinet: N/A
    Channels: One
    Tube Preamp: 12AX7
    Tone Controls: No
    Pull Bright Function: No
    Power Tubes: x1 EL84
    Reverb: No
    Tremolo/Vibrato: No
    Dual Master Volume: No
    Master Control: Volume
    Variable Boost: No
    Effects Loop: No
    Direct Out: No
    Footswitch: No
    Dimensions: 5 (H) x 12.4 (W) x 7.2 (D)
    Dimensions (mm): 128 (H) x 315 (W) x 183 (D)
    Weight: 7 lbs / 3.2 Kg
    Kustom Defender 1x12 - Elektro Gitar Kabini
    The Defender 1x12 is a solidly constructed guitar speaker cabinet with a single Kustom® 12-inch speaker. It is an open-back cabinet design that utilizes a plywood baffle board for enhanced tone and resonance.
    The Defender 1x12 handles 30 watts RMS and is rated at 16 ohms. This Kustom speaker is designed to produce rich, articulate clean tones and respond well to overdriven signals as well.
    The Defender 1x12 speaker cabinet is a great match for the Defender 5H all-tube, 5-watt guitar head. Check out this combination at a Kustom Dealer near you.
    RMS Wattage: 30 Watts
    Speaker: 12", 16-Ohms
    Cabinet: Plywood Baffle board
    Dimensions: 17 (H) x 17.75 (W) x 10 (D)
    Dimensions (mm): 432 (H) x 451 (W) x 254 (D)
    Weight: 20.5 lbs / 9.3 Kg
    FİYAT:600 lira (kafa kabin toplam fiyatıdır PAZARLIKSIZ)
    Son düzenleme: 13 Kasım 2016
    aytarslan ve ogulcaan bunu beğendi.
