Satılık Seymour Duncan Vintage Rails Strat Manyetik Single Humbucker
İstanbul
Single boyutunda Humbucker
4 yollu kablo .Bu sayede single a dönüyor ve klasik strat soundunu alabiliyorsunuz. Hem single hem humbucker soundu.
Single soundu çok iyi tam yumuşak ve parlak strat soundu.Humbucker soundu tok ve rock ,metal gibi soundlara uygun.
Hum-free .(dip ses yok)
ELimde bir bridge 2 de neck olarak var.(middle olarak üretimi yok)Yani isteyene tam set olarak ta satabilirim.Fiyat adet fiyatıdır.
Blade tasarımı sayesinde bend yaptığınızda kayıp olmadan sustain alabiliyorsunuz.
Kutulu yay ve vidaları ile beraber sıfırdan farksızdır.Kablo boyları tam.
TAKAS YOKTUR !
Summary
Hum-canceling split blade design gives you even sustain while bending notes, and delivers single coil like sparkle with vintage output in your bridge.
Description
The Vintage Rails is a single coil sized humbucker with a unique split-blade design that is meant to be wired in parallel to give you a sparkly, vintage style single coil tone without the Strat hum. In the bridge position, this pickup will be tight and crisp, and will give you lots of vintage Strat snap. For added versatility, its 4-conductor leadwire gives you the option of switching it into series wiring (using a pushpull or mini-toggle) for hotter, fatter humbucker tone. This pickup is a drop-in for any single coil pickup route.Pair with our Vintage Rails Strat – neck BlackHand built in Santa Barbara, CA, the Vintage Rails for Strat comes with a ceramic magnet, 4-conductor lead wire, and is wax potted for squeal free operation.
