Yeni içerik
Satılık Revv G3 Distortion Pedal
Antalya
Temiz,Herhangi bir sıkıntısı yok.
  • Distortion pedal based on Revv amplifiers’ purple channel
  • 3 selectable “aggression” settings tailor the amount of gain
  • Bass, Middle, and Treble EQ controls allow you to optimize the sound for any type of pickups
  • Sounds great whether you use it in front of an amp, in its effects loop, with a modeler, or direct into a cab simulator
  • Excels at modern metal tones, versatile enough to cover many other styles as well
  • Tech Specs
  • Pedal Type:Distortion
  • Analog/Digital:Analog
  • Inputs:1 x 1/4"
  • Outputs:1 x 1/4"
  • True Bypass:Yes
  • EQ:3-band EQ
  • Controls:3-way Aggression Switch
  • Power Source:9V DC power supply (sold separately)
  • Power Usage:17-20mA
  • Height:1.25"
  • Width:2.75"
  • Depth:4.76"
  • Weight:0.8 lbs.
  • Manufacturer Part Number:RevvG3
AdBlock Tespit Edildi
