MAYA 44 ses kartı hakkında yorumlar...
Merhaba bu kart hakkında bilgisi deneyimi herhangi bir yorumu olan arkadaşlar varsa benimle ve forumla paylaşmalarını rica ediyorum.
Eş değerli M-Audio kartlarla karşılaştırılabilir mi + ları ve - leriyle...
Kartın satış fiyatı 130 euro (KDV dahil)
TEKNİK ÖZELLİKLER ...
24-bit / 192kHz D/A Converter and 96kHz A/D converter
S/PDIF Coaxial and Optical Outputs
Microphone Preamp with + 48V Phantom Power
Simultaneous Full-Duplex Recording and Playback
Shutter type optical output jack
DirectWIRE 3.0
Universal Board (compatible for both of 3.3V and 5V PCI slots)
Multi channel Digital Pass thru
Supports E-WDM driver: MME, DirectSound, ASIO 2.0 and GSIF 2.0
OS: Microsoft Windows® XP/2000
Expansion Connector for additional Digital Audio inputs and MIDI interface(MI/ODI/O)*
Specifications.
- <Analog Audio>
- 1. Sample rate supports : 32, 44.1, 48, 88.2, 96, (176.4, 192)* kHz *Playback only
- 2. Analog Input :
- 1) Connector Type : 4 Channel analog inputs
- * 1/4" TRS(stereo) jack(line in 1 and 2) common with 'Mic. in
- * 1/4" TRS(stereo) jack(line in 3 and 4)
- 2) Peak level : 0dBFS @ +6dBV
- 3) Programmable gain: -48dB ~ +24dB(1dB step size)
- 4) Impedance : 10K Ohm
- 3. Analog Output :
- 1) Connector Type: 4 Channel analog line outputs
- 2) Peak level: +6dBV @ 0dBFS
- 3) Attenuation: -48dB ~ +0dB(1dB step size)
- 4) Impedance: 33 Ohm(line out 1 and 2), 0 Ohm(line out 3
- and 4, H.P. out)
- 4. MIC Preamp
- 1) Mic Preamp Gain : +21dB
- 2) Peak level : 0dBFS @ 246mV
- 3) +48V phantom power supply
- 4) Impedance : 3K ohm
- 5. Headphone Amplifier
- 1) Load Impedance Range: 32-300 ohm (for the best
- performance)
- 2) Output Power: 125mW @ 32ohm per channel
- <Digital Audio>
- 1. Sample rate supports : 32, 44.1, 48, 88.2, 96, (192)kHz *Coaxial Output only
- 2. A/D Converter
- 1) SNR : 102dBA(0dB @ fs=48kHz)
- 2) DR : 102dBA
- 3) THD : - 95dB(1kHz, -1dBFS)
- 4) Interchannel Isolation : 90dB
- 3. D/A Converter
- 1) SNR : 108dBA(0dB @ fs=48kHz)
- 2) DR : 108dBA
- 3) THD: -97dB(1kHz, 0dBFS)
- 4) Interchannel Isolation : 100dB
- 4. Digital Output
- 1) Connector Type : Coaxial, Optical
- 2) Format : IEC-60958 Consumer(S/PDIF)
- 3) Resolution : 24-Bit
- 4) Digital Pass thru
- UAT(Ultimate Audio Tools) included.
- Tassman ESI by AAS : Modular software synthesizer
- LFX 1310 multi FX : VST multi effector
- ESI Bovbjerg Piano : grand piano sound module
- ESI Atti-tube VST : High quality Guitar/Bass AMP Simulator
- ESI FX pack : 7 effect processors
- Bundled Third-Party Plug-Ins
- Kjaerhus Audio - the classic series (7 complete VST plug ins)
- AudioNerdz - Delay Lama
- MDA-VST - Piano, ePiano
- Sinus - Freeverb Too
- Silverspike - RoomMachine 844
- Abyss - Cushion, Exciter, Filter
- PSP audioware - PSP Piano Verb
- CSI - FFT, C Tuner, C Super Stereo
- Steinberg - Leveler, Tools One, Externalizer
- Stereo Expander
- Voxengo - Stereo Touch
- Smartelectronix - Supaphaser
bende m-audio audiophile 2496 almayı düşünüordumda maya 44 te kaldı aklım..Sizce hangisi daha iyi m-audio nin mikrofon girişi yok bildiğim kadarıyla mayada var sanırm..Birde bu iki karttan herhangi birini alırsak PCI mı USB mi alalım?
USB ye özel olarak bi ihtiyacınız yoksa PCI alın tabi ki..
Maya44 te mic preamp ve phantom power olmasından dolayı consender mic. dahi bağlayabiliyorsunuz. İki kartın teknik özellikleri birbirine çok yakın. Ama maya da midi giriş/çıkış yok örneğin. İhtiyacınıza göre seçiminizi yapın. İkiside kalitelidir sıfıra yakın latecy ile çalışır.. daha iyisi var mıdır? vardır..
