Satılık Ibanez Sr705 5 Telli Bas Gitar
'Bas Gitar ve Aksesuarları' forumunda Racsen tarafından 28 Haziran 2017 tarihinde açılan konu
  1. Şehir:
    İstanbul
    Fiyat:
    2500 TL
    Takasa:
    açık
    Ağırlık: 4,10 kg
    Tertemiz durumda, çizik bile mevcut değildir, üzerinde yeni takım teller bulunmakta.
    Caddebostan/İstanbul’da deneyebilirsiniz.
    Takas sadece müzik aletleriyle olabilir.
    The 5-string Ibanez SR705 Electric Bass delivers clean, punchy bass tone in a sleek playable package. The mahogany body with figured maple top and 5-piece jakota and bubinga bolt-on neck make for enhanced resonance and attack. A U-profile neck with 12″ fretboard radius makes the Ibanez SR705 maneuverable and smooth. Split-coil Bartolini pickups give you all of the kick you need without compromising tone. A 3-band EQ with mid-frequency selector lets you seal in your sound. Cosmo black hardware and a gloss finish give the Ibanez SR705 its sleek appearance and round out this well equipped 5-string.
    • Solid mahogany body with figured maple top
    • 34″ scale
    • 5-piece Jatoba/Bubinga neck with bolt-on neck joint
    • Rosewood fretboard
    • U-shaped neck profile
    • 24 frets
    • Accu-cast B25 bridge
    • Bartolini MK1-5 bridge and neck pickups
    • EQB-3S 3-band EQ controls with mid frequency selector switch
    • Die-cast tuners
    • Cosmo black hardware
    • Gloss finish
    SR705 5-String Electric Bass
    • Scale/Length: 34″ (864mm)
      Width at Nut: 45mm
      Width Last Fret: 67mm
      Thickness 1st Fret: 19.5mm
      Thickness 12th Fret: 21.5mm
      Radius: 305mm
  2. satıldı
