Satılık Nordstrand Dc5 5 Telli Bas Gitar Manyetik Seti (sıfır)
'Bas Gitar ve Aksesuarları' forumunda Racsen tarafından 19 Temmuz 2017 tarihinde açılan konu
  1. Şehir:
    İstanbul
    Fiyat:
    312 $
    Takasa:
    açık
    Paralel bağlı (istenirse değiştirilebilir), P2 boyutlarında. 19 MM aralık, Alnico V
    Caddebostan/İst. Racsen Bass Club'da deneyebilirsiniz.
    Parallel Dual Coil 5 Set
    This is a modern design dual coil humbucking pickup.
    Pickups like these are usually found on very high end basses. They use Alnico V magnets and the traditional bi-pole layout with two poles per string. It’s almost like two Jazz Bass® stlye pickups in one cover.
    These pickups are available in two different versions.
    One set is designed to be wired in parallel, and the other in series.
    The reason we do this is that a pickup that is made to sound good wired parallel will usually be too hot and dark sounding if wires in series. So, we put less wire on a series dual coil than a parallel dual coil.
    In general, a pickup wired in series will have a fuller and fatter midrange with a subdued high end than a pickup wired in parallel, which will typically have more highs and a deeper low end with a cleaner midrange. Series pickups also have more output than parallel pickups. Parallel pickups are generally a better choice for a split-able installation, as there will not be the gain loss associated with series pickups.
