Uzun zamandır düşündüğüm bir amfi nasıldır?
Amfiyi aldigimda denedigim ilk sey the eagle flies alone sarkisindaki introya olabildigince yakin bir sound almakti.
Biraz kurcalamayla basardim.
Sunulan presetlerle biraz oynayinca guzel sesler ortaya cikiyor.
Vt-xl modelinde presetler soyle:
Glass: modeled on the Clean channel of a collectible 100-Watt head named the Overdrive Special
Funked: modeled on a classic American black-faced 2x12 combo
Buzzsaw: inspired by the British-made 50-Watt head that created the sounds of ‘70s hard rock and metal
Crunched: based on a very rare modded VOX AC30/6TBX Top Boost combo, adding new hot-rodded gain levels and EQ
Thrashed: modeled on a 1983, all tube, single channel, master volume 100-Watt head
Raged: based on the high gain channel of a modern, all-tube 100 Watter, with boosted bass and mid frequencies and even more gain
Modern: a still higher gain modification to the “Modern High Gain” channel, with scooped EQ
Fluid: the UK Modern setting with maximum gain and mid-range EQ, modified to emphasize a vocal-like tone for legato-style playing
Molten: based on VOX’s US Hi-Gain model but capable of even more powerful, heavily saturated sounds, with an Octave effect mixed into the preset
Black: a version of the UK Modern mutated to Class A, rather than Class AB
Damaged: rooted in VOX’s US Hi-Gain model with more gain and a completely re-voiced and modified EQ to be thicker and darker.
Modern metal sound icin modern preset,dist 7-8/10,treble 7.5,mid 3-4,bass 5.5/6.5+compressor efekti kullaniyorum,solo kisimlar icinse fluid+reverb.
Clean ayarlarimi sıklıkla degistirdigimden sabit bir ayar yazamayacagim.
Ts808 pedalini boost olarak kullansam guzel bir sonuc alirim diye dusunuyorum.
