Satılık Weber Dt-10 8 Ohm Speaker - Gitar Hoparlörü
Sipariş üzerine el yapımı üretilen dünyaca ünlü Weber marka
Temiz, sorunsuz. Orijinal kutusuyla. Lehimsiz kullanılmıştır.
Düşük db değeri sayesinde örneğin 99db'lik bir celestion hoparlörün 4'te biri hacminde ses çıkarır. Amfinizin sesini rahatlıkla açıp tüpleri ısıtabilirsiniz.
Sadece Istanbul içi nakit.
10", 20oz Ceramic magnet, 30 watt, 1.5" voice coil, inverted-rib seamed cone, 3" paper vented dustcap.
Sensitivity: 93db
Weber's DT-10 speaker provides warm smooth tone with good bottom end. The 20oz magnet helps keep the speaker somewhat inefficient, so you can drive your amp into overdrive more easily than with a more efficient speaker. Excellent replacement for CTS ceramics in Super Reverbs, as well as a solid choice for Princetons and Vibroluxes where you want to get some drive from those amps without a thin and harsh treble. Derek Trucks kullanıyor.
Ted Weber Speakers are hand-built to order, to ensure the best attention to detail is paid to your speaker. We build them one at a time, on a table - not hundreds at a time on an assembly line. This allows us to reduce the margin for error and produce an overall higher-quality speaker.
