Satılık Roland TD11 Modüle & Roland TD11K Pad's Elektronik Davul
İstanbul
V-COMPACT DRUM SOUND MODULE WITH SUPERNATURAL
The TD-11, SuperNATURAL powered entry-level V-Drums sound engine brings a more natural and realistic drumming experience to the entry level. Its affordability and easy operation expands the opportunity for drummers of all budgets and skill levels to use electronic drums for lessons, home practice, and live performances.
New sensing technology with Behavior Modeling provides a complete and natural drumming experience
COACH and QUICK REC functions help build skills effectively at home, school, or any place of practice
Large-sized LCD and simple user interface for easy operation
USB-MIDI/AUDIO can conveniently connect to computer applications
SuperNATURAL Powered
Derived from the flagship TD-30’s SuperNATURAL concept, the TD-11 also provides a complete and natural drumming experience when played with V-Compact series pads. Thanks to Behavior Modeling Technology*, the response becomes much more precise and faster, and the ambience enhances the sounds more realistically — all of which were difficult to realize with the previous sound module.
Beyond the physical modeling of instruments, Roland goes a step further by modeling the instrument’s distinctive behavior and how it responds to the performer, resulting in natural, expressive sounds that evolve organically in realtime.
Internal Songs and Song Player
The TD-11 is equipped with realistic and powerful onboard backing songs and loop phrases, which are perfect for practicing as well as for the pure enjoyment of playing along. With a USB flash drive connected to the module, you can play back audio files (WAV, MP3) directly from the USB flash drive. You can mix the balance of your drumming with the backing track, change the tempo of the song with the Speed Control, loop specific sections with A-B repeat, and take your practice sessions to a new level.
Advanced Practice Tools
Roland’s highly acclaimed Coach Mode is onboard the TD-11, including Time Check, Quiet Count, and Warm Ups — a full set of exercises for self-improvement. In addition, QUICK REC lets you easily record and play back your own performance. This is a convenient way to repeatedly record yourself practicing and evaluate your performance.
Computer Compatibility
By connecting the TD-11 to your computer with a single USB cable, you can transmit audio and MIDI data. It’s a simple, convenient method for interfacing with the DT-1 V-Drums Tutor, V-Drums Friend Jam, and/or your favorite DAW software.
Drum Kits
50
Instruments
190
Instrument Parameters
Tuning, Muffling, Snare Buzz, Strainer, Tone Color, Volume, Pan
Effect Types
Ambience (10 types) 4-band equalizer
Ambience Parameters
Type, Character, Size, Wall, Shape
Song
Preset songs: 14 CD-ROM: SONG: 38, PATTERN: 22
Quick Rec
Resolution: 480 ticks per quarter note Recording method: Real-time Maximum note storage: approx. 30,000 notes
USB Memory Song Player
File format: WAV/MP3
Display
64 x 128 dots graphic type LCD (backlit LCD)
Connectors
TRIGGER INPUT connector (DB-25 type): Kick, Snare, Tom1, Tom2, Tom3, Hi-Hat, Crash1, Ride, Ride Bell, Hi-HatControl
Extra Trigger Input jacks: 1 (CRASH2) (stereo 1/4 inch phone type)
OUTPUT jacks (L/MONO, R) (stereo 1/4 inch phone type)
PHONES jack (stereo 1/4 inch phone type)
MIX IN jack (stereo miniature phone type)
MIDI OUT connector
USB COMPUTER port
USB MEMORY port
Interface
Hi-Speed USB (USB-MIDI, USB-Audio, USB flash memory)
Output Impedance
1.0 k ohms
Power Supply
AC adaptor (DC 9 V)
Current Draw
350 mA
Accessories
Owner's Manual
CD-ROM (Play-along Audio Song/USB Driver)
AC adaptor
Special connection cable
Wing bolt (M5 x 10) x 2
Sound module mounting plate
Options (sold separately)
Pads (PD series, PDX series)
Cymbals (CY series)
Kick (KD series)
Hi-hat (VH-11)
Hi-hat control pedal (FD series)
Stand (MDS series)
Cymbal mount (MDY series)
Pad mount (MDH series)
Acoustic drum trigger(RT-30H, RT-30K)
Personal drum monitor: PM-10,PM-30
V-Drums accessory package: DAP-3X
V-Drums mat (TDM-20/TDM-10)
USB flash memory
* Use USB flash memory sold by Roland. We cannot guarantee operation if other products are used.
SIZE AND WEIGHT
Width
154 mm
6-1/8 inches
Depth
89 mm
3-9/16 inches
Height
225 mm
8-7/8 inches
Weight
665 g
1 lbs. 8 oz.
