Satılık Japon Soloist Jackson SLSMG (Super Lightweight)
İstanbul
Açık
Jackson Soloist SLSMG gitar , neck thru ve aktif manyetikli tek parça maun ve abanoz klavyeli. Gayet temiz ve sadece evde kullanılmış bir gitardır. Çok kuvvetli bir tonu ve sustaini var. Teknik özelliklerini incelemek isteyenler için aşağıda bırakıyorum.
İstanbul içi elden teslim edebilirim. Orijinal Jackson hardcase'i dahildir.
Jackson MG Series SLSMG Super Lightweight Soloist Features:
  • Finish: Satin Black
  • Body: Mahogany with Carved Top
  • Neck: Neck-Thru-Body Mahogany with Scarf Joint Head Stock
  • Neck Dimensions: 3rd Fret: .735", 12th Fret: .810"
  • Tuning Machines: Sealed Die-Cast Tuners
  • Fingerboard: Ebony with Compound 14" to 16" Radius
  • No. of Frets: 24 Jumbo Frets
  • Bridge Pickup: EMG® 81
  • Neck Pickup: EMG® 85
  • Controls: Master Volume, Master Tone
  • Bridge: JT390 Adjustable Bridge with Strings-Through-Body
  • 3-Position Pickup Switching
  • Hardware: Black
  • Pickguard: None
  • Scale Length: 25.5" (648mm)
  • Width at Nut: 1-11/16" (43mm)
  • Compound (14" to 16") Fingerboard Radius
  • Ivoroid Binding on Neck and Headstock
  • MOTO Piranha Tooth Position Inlays
  • 3-Over, 3-Under AT1 Tuning Machine Array
  • Strings-Through-Body with Tune-O-Matic Bridge
128775
