Satılık Lakland 55-01 Kore Aguilar OBP3 Nordstrand Fatstack
İstanbul
Açık
laklandslx1.jpg laklandslx2.jpg laklandslx3.jpg laklandslx4.jpg laklandslx5.jpg laklandslx6.jpg laklandslx7.jpg
Temiz durumda, tüm bakımları yapılı. Kore yapımı 55-01 olan bir bas NordStrand’in Fat Stack manyetikleri ve Aguilar OBP3 devre ile modifiye edilmiş, elde edemeyeceğiniz ton çok az diyebilirim,
Kontroller: Vol – Vol (Push/Pull Humbucker-Single), Aktif/Mute/Pasif Switch, Pasif Tone , Bas/Tiz , Mid ve Mid Switch
Nut width1.81”
Nut typeBone
Fret size.041/.085”
Width at final fret3.3″
1st fret neck depth.81”
12th fret neck depth.92″
Fingerboard radius10-13″
Scale length35”
Frets22
Bridge string spacing.75”
Neck woodFlat-sawn Maple with graphite reinforcement bars
Body woodAsh
These are a proprietary Nordstrand design, born from the angled pole prospects of the bossman himself. The traditional bi-pole magnet layout was rotated 45 degrees, increasing the size of the traditional J style coil by 50%, making the coil wider and instigating the growth of a larger magnetic aperture, facilitating the capture of each string’s unique harmonic characteristics. This results in a fatter tone that is somewhat reminiscent of a J style single coil. However, with the FS’s stacked coil design, its tone is inherently darker, bolder, and fatter. The Fat Stack presents a range that cascades across the sonic spectrum, providing a present but pleasant high end, a detailed midrange, and full-bodied low end. Due to the naturally occurring lower output of its design, these pickups benefit greatly from a pre-amp with 3 or more db of gain.
  • Bass Kontrol: plus/minus 18 dB @ 40 Hz.
  • Mid Kontrol: plus/minus 16 dB @ 400Hz ve ya 800 Hz.
  • Treble Kontrol: plus/minus 16 dB @ 6.5 KHz.
  • Giriş Empedansı : 1 meg ohm
  • Çıkış Empedansı : 100 ohm 9 ve ya 18 volt. 18 volt ile fazladan 6dB elde edersiniz.
  • Distortion: .019 into 10k ohm
  • Noise: -95 dBm
  • Pil Ömrü: 324 Saat
AdBlock Tespit Edildi
