Satılık Marshall DSL 40CR
Antalya
Merhaba arkadaşlar,
Ampli geçen sene Zuhal'den alındı. Hiç bir sorunu yoktur. Kutusu, kullanım kılavuzu bile duruyor.
Zuhal satış fiyatı 7,600 YTL'dir. Az miktarda da olsa pazarlığa açıktır.
TECHNİCAL SPECİFİCATİON
GENERAL
Model
DSL40CR
Range
DSL
Technology
Valve
Channels
2 (Split) "Ultra gain" and "classic gain"
ELECTRONİCS
Output wattage
40W (with power reduction option to 20W)
Outputs
Speaker outputs: 5 x 1/4" jack sockets (16Ω load / 8Ω load / 4Ω load), 1 x 1/4" jack emulated line out
Inputs
1 x 1/4" instrument jack, 1 x 3.5mm jack Aux in MIDI in, footswitch
Controls
Classic gain channel (gain, volume, clean crunch switch), ultra gain channel (gain, volume, OD1/OD2 switch), treble, middle, bass, tone shift switch, presence, resonance, reverb (classic gain channel), reverb (ultra gain channel), master select switch, master volume I, master volume II, loop on/off switch, low power option (on rear)
Effects
Digital reverb
Effects loop
Yes, series, send/return
SPEAKERS
Speaker configuration
1x12"
Speaker model
Celestion V-Type speaker (16Ω, 80w)
Unit impedance
16Ω
VALVES
Preamp valves
4 x ECC83
Power amp valves
2 x EL34
ACCESSORİES
Footswitch
PEDL-90012 included. Compatible with PEDL-91016 modes include: 1 - Clean (classic green) 2 - Crunch (classic red) 3 - OD1 (ultra green) 4 - OD2 (ultra red) 5 - Master 1/Master 2 (toggle) 6 - FX Loop on/off
Cable
Detachable power cable included
Dust cover
M-COVR-00116 (sold separately)
DİMENSİONS (İNCLUDİNG FEET AND HANDLE)
Weight
22.9 kg / 50 lbs
Width
620 mm / 24.4"
Height
490 mm / 19.3"
Depth
252 mm / 9.9"
AdBlock Tespit Edildi
