Satılık Musicman Steve Morse Signature
  • Konuyu açan Konuyu açan Amt
Amt
Takefive
Antalya
Açık
USD
2007 Usa üretim, orijinal hardcase dahil.
Takas usa e. gitar , tone king imperial amfi ile olur. Altı üstü konuşulur
Serial # G10477
Manufactured April 4th, 2007
Build Code 900-72-21-06-CS-CR
Model Steve Morse Hardtail
Color Morse Blue Burst
Neck Maple Neck Rosewood Fretboard Matching Headstock
Hardware Chrome Hardware
Specifications Steve Morse
Model Steve Morse
Size 12-1/2" wide, 1-3/4" thick, 36-7/8" long (31.8 cm wide, 4.5 cm thick, 93.7 cm long)
Body Wood Poplar
Body Finish High gloss polyester
Bridge Tuneomatic bridge with thumbwheel height adjustment & individual saddles with Music Man® chrome plated, solid brass tail block
Pickguard Black
Scale Length 25-1/2" (64.8 cm)
Neck Radius 12" (30.5 cm)
Headstock Size Only 5-7/8" (14.9 cm) long
Frets 22 - High profile, wide stainless steel
Neck Width 1-5/8" (41.3 mm) at nut, 2-1/4" (56.9 mm) at last fret
Neck Wood Figured roasted maple neck
Fingerboard Rosewood
Neck Finish Gunstock oil and hand-rubbed special wax blend
Neck Colors Natural
Tuning Machines Schaller M6-IND locking
Truss Rod Adjustable - no component or string removal
Neck Attachment 5 bolts - Sculpted neck joint allows smooth access to higher frets
Electronic Shielding Graphite acrylic resin coated body cavity and aluminum lined pickguard
Controls 250kohm volume and tone - .047µF tone capacitor
Switching 2-way toggle, 3-way toggle pickup selector; 3-way lever pickup selector
Pickups HSSH - DiMarzio (neck to bridge); Humbucking - DP-205 Morse Signature; Single coil - DP-108 Vintage; Single coil - Proprietary custom wound; Humbucking - DP-200 Morse Signature
3088FF1E-B29F-4061-8426-E39406489BAD.webp.jpg D980983E-90A9-4F5F-AD0A-F59A2A5AD902.webp.jpg E65234C0-CB3B-40D3-A7DD-64A08CA4479A.webp.jpg B91F9F8D-08B0-4A37-9F23-03A6F8C73C51.webp.jpg 4CCBC7EF-6415-40B9-8802-A39DA3194980.webp.jpg 4F3A1BA2-9466-4ADD-A9AC-B9AA44FF2B98.webp.jpg 1A63094A-0990-4AAA-B2A9-AC389F3EDE3B.webp.jpg 6BEF44E8-A6C1-4CF0-9A58-A6E8E0A77469.webp.jpg B576422A-2364-4419-A986-48EEDBB26CEA.webp.jpg 2E566E53-3EAE-4951-A785-4D24182713D8.webp.jpg 6B87A30B-1F96-4932-B696-F8915D0E0A56.webp.jpg
