Tamam Türkiye'de bulunmayan şeyler biraz daha yüksek fiyata gidebilir, eyvallah da... 10£ potu 250₺ 7£ potu 175 liraya satmak da ne biliyim..
Satılık - CTS 250k vintage %9 tolarans pot
6 adet sıfır (CTS 250V) CTS Guitar Pot, 250k Pot Premium 450 Series 9% Tolerance (Vintage Style) 1 adet fiyatı yazılmıştır.turkrock.comGuitar Pot, 250k (275k) Mini Split Shaft Audio Taper Pot 9% Tolerance
Finally, a top quality mini pot that's as good as the large ones. 275k knurled shaft mini potentiometer, (16MM) ± 9% tolerance, bushing 3/8-32 threads, 3/8 in. bushing height, shaft .238 in. (6.3mm) diameter 24 splines, 3/8 in. shaft length, requires 3/8 in. mounting hole. These are developed...www.wdmusic.co.uk
Satılık - CTS push-pull dptd 500k long 24 split saft
4 adet sıfır CTS Push Pull DPDT Pot Long Shaft, 500k Audio Taper, Spilt Shaft (24 Spline) 1 adet fiyatı yazılmıştır.turkrock.comPush Pull DPDT Pot Long Shaft, 500k Audio Taper, Spilt Shaft (24 Spline)
Supplied complete with 1 x nut, 1 x washer and 1 x lock washer, this 500k audio taper (log) pot is CTS's own push/pull pot allowing for various additional wiring possibilities such as coil-tapping or phase switching. 24 spine split shaft for USA-Fender or Gibson knobs to push-fit straight on (or...www.wdmusic.co.uk
Satılık - Swichcraft 3 toggle les paul ve SG Swich
1 adet Switchcraft Exact Replacement Toggle Switch for Gibson - Nickel 350 tl 1 adet Switchcraft Right Angle Toggle Switch for SG - Nikel 300 tlturkrock.comExact Replacement Toggle Switch for Gibson
Switchcraft toggle switch, as used by Gibson in their U.S.A. instruments such as Les Paul's and ES-335's e.t.c. Comes with cream tip and mounting nut, other switch tip colours are available, please see here. Please note that, as with all Switchcraft switches, the contacts have been pre-tinned...www.wdmusic.co.ukRight Angle Toggle Switch for SG
A Switchcraft right angle toggle switch, as used by Gibson in their U.S.A. SG's. As standard, the nickel version comes with a cream tip, mounting nut and washer. The gold version comes with a black tip, other switch tip colours are available - please see here. Please note that, as with all...www.wdmusic.co.uk
Solo müzikte var sanırım, ilanlardakilerin bir farkı var mı? Bence yok.
CTS Gitar Potansları
Gitar, bas hardware. Knoblar, potlar, eşikler, vidalar, tremololar, floyd rose, tremolo kolları. Gitar yedek parçaları ve aksesuarları. Guitar parts.
www.solomusicankara.com
CTS Push Pull Potansları
Tüm gitar, bas hardware. Knoblar, potlar, eşikler, vidalar, tremololar, floyd rose, tremolo kolları. Binlerce çeşit gitar yedek parçaları ve aksesuarları.
