FRACTAL AM4
Taxle beraber 350 dolar gibi. Benim gibi fazla block ihtiyacı olmayanlar için mantıklı olabilir.
Ayrıca bir yoruma göre:
“You might think the 4 blocks available in the AM-4 are not enough for your needs (especially if you're new to Fractal), but try to picture what you really need in your signal chain and then consider this stuff the AM-4 offers:
  • noise gate always available at the input
  • input boost (several types) in the amp block
  • output boost in the amp block
  • input PEQ in the amp block
  • output or pre-power amp GEQ in the amp block
  • Output comp in the amp block
  • bias tremolo in the amp block
  • stereo cab included in the amp block
  • mic preamp in the cab section
  • room reverb in the cab section
  • simple delay included in the reverb block
  • you can attach an expression pedal to any of the several volume controls available or assign it globally to the input or output (without the need to waste a volume block)
So, with just two blocks used (Amp and Reverb), you already have a chain like this:
Gate > Boost > PEQ > Amp > Tremolo > GEQ > Comp > Boost > Cab > Mic Preamp > Room > Volume pedal > Delay > Reverb
And other 2 blocks to add whichever other effects you'd like, either pre or post amp/cab
PS: to have a chain like this in e.g. an Hx Stomp, you'd need far more than the 8 available blocks.”
