200 Euro civarında olanlar genelde Vietnam üretimi oluyor, yine de kullananlar genel olarak memnunlar.
				Electric Guitar  Custom Line series, Body: Meranti, Glued-in neck: Meranti, Fretboard: roasted jatoba, White pearloid crown fretboard inlays, Neck profile: Modern-C - thickness at the 1st fret: 20 mm, thickness at the 12th fret: 22 mm, Binding:...
					www.thomann.de
				Electric Guitar  Custom Line Series, Meranti body, AAAA Flamed maple veneer top, Meranti neck, Roasted jatoba fretboard, White pearloid crowns fretboard inlays, Modern-C neck profile - thickness at the 1st fret: 20 mm - thickness at the 12th fret:...
					www.thomann.de
Şu şekilde LTD Eclipse benzeri bir gitar düşünebilirsiniz.
Floyd Rose 1000li 25,5 inch skala Eclipse buyrun.
				B-Stock with full warranty  Slight traces of use   Electric Guitar  Custom Line series, Mahogany body, Set-in mahogany neck, Roasted Jatoba fretboard, White pearloid crown fretboard inlays, Ivory coloured binding, Neck profile: Modern-C - thickness...
					www.thomann.de
Şu SC 550'yi de baya güzel satmışlar ve baya beğenilmiş, bakabilirsiniz.
				Electric Guitar  Weight relief chambered mahogany body, Arched AAAA flamed maple top, Set-in mahogany neck, Fretboard: Roasted jatoba, Fretboard inlays: Pearloid trapezoids, '60s neck profile, Fretboard radius: 350 mm, Scale: 628 mm, Nut width: 43...
					www.thomann.de
200 Euro'yu aşıyor ama şöyle Fusion diye bir serisi var. Baya güzel özellikler var üzerinde çelik fretler, Grover tuner'lar, Floyd Rose'lusunda da Floyd Rose 1000'li yine. Endonezya üretimi
				Electric Guitar  Ergonomically shaped sapele body, Matching headstock, Top: "Ultra Flame" flamed maple veneer, Bolt-on neck: Canadian hard maple, Fretboard: Canadian hard maple, Fretboard inlays: Clay dots, Neck profile: Modern C, 24 Medium jumbo...
					www.thomann.de
Yine Endonezya üretimi bu fiyata bu gitar nasıl olmuş diye düşündüğümüz Metallica Explorer'ı
				Electric Guitar  Pro Series, Body: Mahogany, Neck: Mahogany, Neck attachment: Set-in, Fretboard: Ebony, Fretboard inlays: White dot, Neck profile: Slim Taper "C", Neck thickness at 1st fret: 22.5 mm, Neck thickness at the 12th fret: 25 mm, Fretboard...
					www.thomann.de
Amarok'u da bırakayım, bunun da 6-7 telli ve bariton versiyonları var.
Neck thru - EMG manyetikli - çelik fretli gayet güzel bir gitar.
				Electric Guitar  Body shape: Arched Modern Comfort, Body: Mahogany, Flamed maple veneer, 5-Piece neck: Maple/Mahogany, Neck attachment: Neck-through-body, Fretboard: Macassar ebony, Fretboard inlays: White 6 mm offset pearloid, Glow-in-the-dark...
					www.thomann.de
İyi incelemeler.
